/6 Matt
30 Degrees Crooked
So I'm finally ready to work on my ignition system and I have some questions.
First what kind of spark plug do I use cause I can't remember. Something from a '96 Dodge V6 motor with the metal washers removed. Were they Intrepid plugs?
Second, what's a good set of wires to use?
Third, I want to use this coil: http://www.summitracing.com/parts/SUM-G5220/ Will this work with my factory replacement ignition module? Sadly I know nothing of prmary resistances and whatnot, so I don't want to fry my module.
Third point five, given I can use the summit coil, what kind of plug gap can I get awqay with here?
Fourthly, this one's not ignition related, what can I do to fix a persistant leak on the economizer valve cover of a holley 1920 pea shooter?
Thanks in advance guys, I'll be watching.
