Turbo QS
mopardart72
I'm a pretty big deal
Laquey missouri
I was wondering if a daytona turbo would fit on my dart i have it all here from my old daytona that i parted but i dont know if it would fit do you know? its the newer daytonas like 90s i think. if you can give me some help i would be appreciated oh and its also goin on a 318 if that helps
I'm not extremely familiar with turbos, but I have read up on them some. I can tell you that the turbo you have will be way too small for the 318. a T4 or something similar would probably be closer to what you need. I'm not sure two of the daytona turbos would even be enough.
I'll give you some links full of information.
http://www.dune-buggy.com/turbo/turbo.htm
http://www.theturboforums.com/smf/index.php?PHPSESSID=a4ed54616eed8c55977e561c697657f8&board=21.0
http://www.turbobygarrett.com/turbobygarrett/tech_center/tech_center.html
http://www.racetep.com/turbo.html#tsc
There, that should keep ya busy for awhile.
That turbo is too small on a slant six; I'm speaking from personal experience; I had one on my Dart for a while and it would make 10 psi of boost at 1,500 RPM and run out of breath by 3,000 RPM. On a 318 it would be worse. Maybe if you had a second one you could go for a twin turbo buildup, though depending on which turbo you have it may be too small even for that. Is it a Garrett or a Mitsubishi?
