pastortom1
I'm at wits end with this one (like most wiring problems).
I have absolutely no turn signals. No power is being sent from the switch to anything....no indicators, no signals, no power at the flasher terminals.
I checked the plug at the end of the switch harness.... looks good and clean.
4 ways work, but a bit fast I think...not too bad. Tails work, parks work, brakes work......power goes into the switch harness and fires the 4 ways, but no power goes to the turn side of the switch unless the 4 ways are on.
There are 2 terminals that are hot in this harness. One is the 'horn hot' (black with w/stripe), and a pink wire that goes into the 4 way switch.......BUT, that pink terminal is 'voltage impaired'......it seems to be going through a resistor or something, where the 'horn hot' is full battery. Horn works fine too.
The switch worked perfectly before we installed the new Grant steering wheel.....BUT, we can't find any wires missing or disconnected........WHAT ARE WE MISSING?
Dead turns mean no drive. If you have any pointers, we could sure use your help on this one.
Thanks guys............................
