So I was on my voyage into work this morning with my 70 Dart I just bought. When I started it and turned on my headlights, I noticed that my green turn signal lights on my dash were both lit up, not blinking. Any ideas?
WELCOME TO FABO!
Ok, I'll give a shot at helping, but keep in mind there are others here at FABO more qualified than me but here goes for Hoosier Daily Dart Drivers back in the hollar experience;
1; Headlight switch
2; rust/corrosion on circut board contacts on back of Inst. panel.
3; Bad bulbs somewhere in system.
4; Bad Flasher unit.
5; firewall contact blocks need cleaning.
6; and just incase that wasn't enough possibilities, how bout a bad ground or wire contact somewhere in circut.
Me? I'd check bulbs first. (front and rear turn signal bulbs)
Then take note: I have replaced headlight switches in EVERYONE of my Darts at least once for each car (mechanical switches wear out) and have replaced enough of them to keep a brand new switch "in stock" in my own home garage!!) It's a $15.00 part available; Advance, Auto Zone, NAPA.
Then flasher unit.
Then if still not fixed, start diggin for loose or rubbing wire.
Good Luck and keep us posted on progress.
Get some pics of your ride posted here, K?:glasses2:
