[SOLD] Turn signal switch
64cudaV8
TX
Does anyone have a good working turn signal switch that goes in the steering column. I need it for a 64 Barracuda. Other years do work just don't know which. Mine wont trigger the drivers side turn signal. Hopefully someone has one. preferably no wires cut.
Whatever you end up doing, try to get an OEM switch, as most of the aftermarket suff is crap and sometimes doesn't even work right out of the package.
You should probably contact Daniel Stern (/6 Dan) on here.
He has access to, or knows where to get the good stuff.
Thanks bud. I appreciate it. I would rather have a good used working unit at this point. Not looking for brand new that may or may not work right. Not needing NOS because the price for those is sky high
I fixed mine opened it up and repaired connection. BE CAREFUL!!
