[Found!] TURN SIGNAL SWITCH
WAYNE0
milton pa.
Looking for a nice used turn signal switch for my 67 barracuda. The white plastic camber piece is shot. I have no problem splicing wires if need be.
There are cancel cam repair kits for those as long as the electrical part still works. they're not particularly hard to install, but, you need to take a bit of care doing it, so, you don't damage the rest of the switch. I used to have some of those......If I run across one, I'll post it here.
It has been my experience that a cam kit won’t fix an electrical issue. If it is just a tab broken off the cam you might get away with it.
The replacement turn signal switches come with the connector body uninstalled so you can fish the wires down the column.
both plastic pieces on mine are broke from what i have found you only get the one piece with the repair kit
