Turn Signals Work but not Hazard
Manny Valencia
Los Angeles, CA
Hello
1972 Dodge Dart
Just want to hear some theories on why my turn signals work but not my hazards.
I bought new relay, my theory is due to bad instrument cluster grounding or instrument circuits not activating?
Have you tested the hazard switch itself? They are weak and just a tad old. If the correct hazard relay does not work try figiting with switch a tad and see if they fire off.
Alright guys come ON. What are we working on here? Year make and model BECAUSE IT MATTERS
The hazard system uses a separate flasher, by the way
Mopars don't use a relay in the turn signal / hazard system. Maybe you are referring to the flasher?
Two differnt flashers as mentioned.
Both in place & hooked up?
If so, one may be bad.
I have reversed their places to see if the issue suddenly moves to the other circuit before.
Some early cars had an add on hazard device. A bit later had a dash mounted toggle, like my 67. At some point the hazard switch was incorporated into the turn signal switch
It is IMPORTANT to tell us what year and model you have
1972 Dodge Dart as says in my original post
OK FINE what have you done, what have you checked
The hazard flasher is supplied separate from several other circuits. The flasher is fed power at all times and goes directly to the hazard switch incorporated in the turn signal switch.
You have a shop manual? Can you read schematics?
The hazard circuit if fed off the same fuse that feeds the dome lamps. Do they work?
That fuse also powers the stop lamps. Do they work?
