Turning Radius Issue
MoparMic
My Garage
I have 68 lower control arms and 73up spindles lower ball joints and upper control arms. I went to check to see about clearance with my FW headers and oil pan but I`m getting no were near them the ball joint is hitting the lower control arm. Is there something I need to cut
You have the bolts facing the wrong way . Nuts go toward the rotor. Short rounded heads of bolts toward the control arm and are the used for the stops. not the nuts.
I`ll give it a look today but its the lower ball joint stop that is up against the lower control arm in the top pic the bolts don`t even get close.
Nope. Nuts go toward the control arm like he has it. This looks like a big bolt pattern conversion. If he puts the nuts out, they will hit the rotors. I went through this problem with my big bolt conversion. The ball joint has a nub on it that hits the control arm way before the bolts. It's because it's desinged for a different car.
I had to set my toe in, then carefully file down the nubs equally until I could get a decent turning radius.
I looked at my car you are right.
This will be an asset for you. You can file/grind the nubs just enough to have the tires not hit the headers.
Good tip man thanks I wasn`t sure if I should grind on the lower ball joint but I was told its forged so grind away
Just rev it up and dump the clutch, it will come around just fine! :-) Actually good information for me because I have the parts to convert my 70 swinger but not at the point to install yet. Thanks!
