[WANTED] Twin snorkel hood scoop for Duster
Valleyant
Valleyant
Cincinnati, Oh
I am looking for a good used twin snorkel hood scoop with attaching hardware for my '74 Duster. I plan to paint it the same color as my car....Golden Fawn. What have you got? Thanks...shipping will be to 45219....Thxs
I got this one off evilbay. Not too bad. Front openings will need a bit of body work to be smooth, rounded, and opened up nice. Requires a bunch of sanding and filing on the mating surface and a little bodywork to fit flat. Pic shown of the side and front of a 69 barracuda hood was after I already ground and filed the **** out of to fit. For some reason theres a notch that was cut in the center of the back when the manufacturer cut this out of the mould. I will have to fiberglass that up. It does however pick up the stock mounting hole locations lining up with the access holes in the inner web of the hood. I used 1/4-20 threaded rod to make studs, then used SEMS nuts to bolt it on. I think I payed about $150 for it. It's not OEM but is pretty decent for the price considering the OEM ones are about $400-$500 for a real nice one
I got some for my Dart Sport from AAR Fiberglass years ago. Very happy with the quality & fit. But it's been a while.
Unless the source has a mold for a Duster hood, I would think that the flatter base version for a Dodge Demon would fit better on a Duster hood than the Dart Sport version which has a "peak" up front to match the hood contours. Those scoops were never available as an OEM option on Dusters.
('73+ Darts have the same hood size & contours as a '69 Barracuda.)
Yes they do. Hood I put this on was off a 74 dart, installed on a 69 barracuda. Have to use 73-76 A body hood hinges with it though.
