cuda65vpt
cuda65vpt
Anyone need to race backwards?
Industrial drive tach. There are internal combustion engines out there that are designed to run both directions. Typically, this was more common before people really started getting into fancy transmissions, before the automatic transmission was in common use as well as other types of transfer cases and gearboxes that allowed industrial equipment to have multiple speeds in both directions.
I think youre all full of crap lol!
If the engine is running backwards, why would the tach? Since a tach only measures the frequency at which the ignition coil is grounded? Or how many times a crank/cam/distributor trigger is fired?
There still exists both steam and marine diesels which run either way. Some boats / ships have no neutral or reverse. You simply stop the engine and start it the other direction.
Early Mercury outboards did this as well Some of them had TWO starter motors. My Dad's old boss went for a ride (he sold Johnson) with the competing 'Merc guy who wanted to show off. Came roaring up to the boathouse, and the damn thing would not start in reverse. Damn near went through the rear of the boathouse. This was in the late '50's
Stuff like the old "hot bulb" or "semi" diesels with run either way
LOLI think youre all full of crap lol!
This is known as "fun at the docks" LOL. That is when they don't start when ya really need 'em
My ex wife could. You should see her back out of the driveway.... No breaks between reverse and drive..... Just shocks the drivetrain....
My '72 Datsun 240Z has a cable feed tachometer from the factory. It bounces all over the place,.
Both of my Harley Davidson golf cart gas engines runs in both directions.
Lots of ways to operate a tach besides off the coil. Some marine tachs for things like 2 strokes and diesels operate off the AC ripple frequency of the alternator. They have to be calibrated to this, and of course if it's belt drive, you don't want the belts to slip
But this is, I'd bet, a flexible cable drive, just like a speedometer. Of course modern speedos aren't cable drive, anymore, either.
"Back when" some of us were playing with early CD ignition, and I could NOT get a tach to work right off one, I had a Joes / Motrola cable drive tach in my RR
(and yes I spelled that correctly)
These were also sold under the Moon and Moroso name, and probably others, similar to this
