saw a thread someone posted, they listed parts they used year of mastercylender. can somebody point me in the right direction, I've been through pages of threads but no luck.
I used the entire assembly from a 67 Cuda with K-H disc brakes on my 66. I sourced all of the hardware from the 67 that couldn’t be bought aftermarket such as the spindles and brackets, and the distribution blocks. I ordered lines for a 67 to get the dual master lines, and used a master cylinder from a 69 Dart with manual disc, because I have manual brakes. The MC is a split bowl, but it’s a 50/50 split, and it works just as it should as it is correct for my application.
69 Dart with manual Disk brakes? Do you mean drum?
True, I have factory front disc brakes on my 67 BarracudaNope, manual disc. They were an option on all A bodies.
