U bolts for springs
hippy 60
Lansing,N.C.
I'm looking for a good set of u bolts for a 7.25 rear end mine are rusted and pitted like to have a better set and also looking for the starter bolts the bolt on top and the stud with washer and tap on the bottom for a v\8.Thanks for any help
Ubolts are easily made by dimension. Visit your local machine shop.
The starter bolt is 7/16" coarse thread and about 1 1/2" length grade 5 minimum or grade 8... You can get them at any hardware/home improvement store...
The stud is 7/16" coarse thread into the trans and 7/16" fine thread for the other end and the nut and goes in the top hole of the starter....
You can order from Grainger if you don't have any local source:
Bolt:
hex head 7/16"-14 dia./thread unc products - Grainger Industrial Supply
This stud will work but is 7/16" 14 thread on both ends, so you will need a 7/16" 14 nut to match it...
TE-CO 2" Steel Double End Threaded Stud with Black Oxide Finish; PK2 - 1DV13|40602 - Grainger
