UCA question
spudsterier
mendota, il
what exactly is the difference between the UCA on a front drum car and a front disc car?
anyone got a pic of both side by side?
thanks
The difference is the diameter of the threaded hole where the upper ball joint screws in it. 73 up disc brakes use the larger upper ball joint.
For the 66-72 Kelsy Hayes disc brake cars, there is no difference in UCA's
I don't know of any difference for 1973 or newer A body cars. The both use the large ball joint.
