straightlinespeed
Sometimes I pretend to be normal
I did a quick search here but didnt find much.
I thought a good discussion on greasable vs. nongreasable ujoints would be good.
I know there are a lot of various opinions on this subject. Such as well the factory never installed them and they lasted X amount of years.Or Greasable are weaker. I would like to know your opinions on this subject.
Heres my own thought. I believe they have a place and time. For instance I built a off road jeep and every single suspension point and anything that could be greasable was. Mostly because it was going to be submerged in mud and water. Now for my Scamp I dont believe that say driveshaft ujoints have to be greasable, but I like the service factor if they are. Now this is were I get a bit iffy on the subject and not sure if its a good thing or not.
I kind of look at it this way. All of the steering linkages have grease zirks on them. They get used turning side to side. You occasionally give them a shot of grease and they seem to last a very long time. Now on a driveshaft you have your ujoint that is spinning gosh knows how much all of the time. Its always twisting and turning. Yet they originally never came with zirks. Why is that? Wouldnt you want them to get a shot of grease every now and then along with the rest of the points on the car?
So are you guys for or against greasable ujoints? What are your opinions of the pros and cons?
