I am almost to the point of taking my '68 Dart 2dr hardtop off the rotisserie and getting it back on the floor. I have a number of questions for everybody to chime in on.
1. It's been on the rotis for 20 years!!!! Yikes, I know! No special bracing for doors or anywhere else. What should I anticipate in terms of trying to get things lined up and properly fit? Should I expect a significant amount of distortion in the body and frame rails?
2. I would eventually like to install sub-frame connectors, and I also want to add torque boxes. Should I wait until after it's back on the floor to put in the connectors just in case there has been some distortion of the body?
3. I want to apply an undercoat to the body/frame. I assume that this is best done while it is still on the rotis. I live on the Texas Gulf Coast so we don't have a problem with road salt, etc., but we certainly have our share of rain and humidity. The undercoat needs to be a shield for that and also a sound deadener. What brand or type is recommended?
4. I will finally paint the underside with the final body color. I'm not looking for show quality, but I want something to blend with the body so wheel wells, etc. don't stick out like a soar thumb. I notice that Sherwin Williams has a line of paints that they advertise as matching original factory colors. Have any of you ever used SW for this? Otherwise, what source/manufacturer do you recommend? I want to use yellow; in Plymouth cross reference they called it Y2 Sunfire Yellow, but I think Dodge just called it plain old yellow for the Dart.
