Pirate duster
ok. i have a 318 that is legitamely built up. I had someone tear the motor down and replace every single gasket on the darn thing. They never took down any casting numbers or serial numbers for me like they were supposed too. Everything is back together minus the carb. and headers and the block is freshly painted and I dont want to buy another gasket set. First question is, can i take the heads back off and reuse the gaskets(metal) and second, I dont how big a stall convertor i should go with. I got a 727 behind it, just because it only cost me $25 bucks.. when im idling in gear the car tries to lunge forward. i dont know jack about the motor other than its got plenty of power. Any suggestions on what stall i should go with?
