To answer my own alarmist question, yes Wilwood does make a front disk kit for 1973+ factory disk cars. What they don't make is a kit for 1972- factory disk cars (Kelsey-Hayes spindle).
72bluNblu may want to read this link:
www.reddit.com/r/cars/comments/430c7l/eli5_why_are_drum_brakes_worse_than_disc
megacookie says exactly the same as I did, i.e. tires stop the car. If the brakes are strong enough to lock up the wheels, they can provide the ultimate braking (just before skidding). Specifically, mega says:
"If it's just a matter of providing the braking force (or torque, technically) to your tires which dictate how quickly you can stop, then drums and discs are pretty evenly matched."
mega is obviously technically educated since he/she doesn't use kid-terms like "powerful", "great pedal", and such. You do see that fluffiness in most articles, even in car magazines from those who didn't learn physics. Given equivalent friction material and such, and the same OD, drum brakes actually provide more braking force on the wheel at the limit of "fade" (where friction force doesn't increase with clamping force) because drums shoes act closer to the OD and have more friction surface area. That also generally takes less line pressure due to the self-amplifying effect of the shoe pivots. Of course, there are many other factors to compare like poorly maintained drum brakes, the amplifying effect is bad if the shoes get gummy stuff (grease, brake fluid), and drum brakes don't dissipate heat as fast. That later isn't an issue in stopping once from 70 mph, but is a big problem if riding the brakes down a mountain or constant hard braking on twisty roads.
Re tires stopping the car, a recent Motor Trend reviewed the new top Camaro and Mustang models. Both stopped from 60 mph in <100 ft, which is amazing. That is most likely due to new sticky tires. Don't rely on the factory spec's on classic Mopars which tested with bias-ply tires. With good tires, optimally proportioned F-R ratio, and good driver technique, your car should be able to stop almost as fast.
