steveb
Member
What is the best way to remove and install the upper control arm bump stops on a 1971 Dodge Dart Swinger? Will I have to loosen and lift the control arm up to give enough clearance to remove them? If I loosen and lift the control arm to get the clearance will this put the front end alignment off?
Thank you
Thank you
