63dartman
I was "tweaking" my upper control arms and tightened the cam bolt nut too tight and stripped the nut. If I need the cam bolt, does anyone know where to get them for early a-bodies? It's the one that has the eccentric welded to it and goes through the upper control bushing and used to adjust the camber I believe.
