Upper Control Arms
70408dart
70408Dart
Crete, Illinois
This has probably been asked before but here we go. Upper control arms from a 75 Dart Sport with drum brakes. Would they be the ones with the big ball joint? I have 70 Dart which I want to convert to disk brakes/big bolt pattern. Would the spindles, caliper brackets and dust sheilds from an Aspen (F-body I think they are) work with the correct upper control arms and correct lower ball joint ?
measure them, they should be the larger ball joint. & the aspen /volare swap has been done & many people have had great results. Lawrence
Go to Bigblockdart tech section and it will tell you everything.
Treblig
