Upper control arms
roadripper
Brandon,Manitoba
So was at the wrecker yard the other day and there was a dart there with drum brakes on it . I checked for Vin # but the dash was gone , so can't verify the year , I have a picture of the body tag I think it's a 74 ! Would those control arms be the ones I want for a 73 and up disk brake conversion ? Not sure if it has small bolt pattern or large ?? Thanks Mike
It's a 74 like you thought and most likely small bolt pattern hubs since it has drum brakes.
I "think" the upper control arms will work for your BBP swap.....Someone else will be along to confirm.
6pk2goDemon is correct. 73-76 uses the larger upper BJ and will work with the BBP swap/conversion.
thanks
James
So it won't mater if the drums are small or large bolt pattern? ? Should be the large ball joint ??
Thanks Mike
Correct it is based off the bj. The 73-76 used what is called the large upper ball joint. Which was the same as the B and E bodies. The early a's pre 73 used a small upper bj.
Thanks
James
You better go get them before someone else does and posts them here for $200 in the for sale section.
you've noticed that too, eh? I understand the concept of supply and demand economics, but that doesn't make it any less frustrating seeing someone selling 40+ year old rusty crusty pieces of **** that need new bushings and ball joints and are sometimes bent during removal (yes, it happens, ask me how I know) for $100 or more...it won't be much longer before buying new tubular ones (arguably better due to modern manufacturing) is a better option anyway.
rant off...
rant off...
Some folks get bored and will do anything to make a quick buck.
So went the wrecker yard today got the control arms 85 bucks
last pair there
Thanks for the help on this
Mike
lame...well, at least you got the arms...bushings and ball joints are inexpensive, at least.
thanks
James
I'm a newb on the forum not sure how to post but I have a question.
I am working on a 75 dart sport was a slant six drum brakes I am reading different things about the uca's I want to convert to disc in the front but am being told I will need to change the uca's others say I already have the lbj how do I tell if I have the lbj's
I am installing a 360 in it also. will I need to change the tranny cross member?
Being that your car is a 75 it would have the large upper ball joint regardless of being a drum brake car. That car used a BJ 10162 the larger upper ball joint So you would only need to get the disc brake spindle, brackets and hardware to do the conversion.
For engine the k members are different between the slant six and the v8, but there are vendors that make modified engine mounts to put v8's into a slant 6 k member if you don't want to change it
Thanks
James
