Upper control arms
bob7four
New Jersey
Not sure who deleted my message but I was only looking for suggestions as to where to purchase NEW control arms. I am not interested in posting a parts wanted ad to buy someone's used parts. This site is exasperating at times
Dr. Diff-
Out of stock at the moment, but he's pretty good about getting things restocked. Give him a CALL and see if he has an ETA.
Mopar Upper Control Arms
And just as an FYI, large ball joint UCAs will be listed as '73-'76 A body, but will fit your '69 just fine when using the later disc knuckles.
Normally a '69 Barracuda has small upper ball joints.
UCA6076 by rightstuff
6374SCA-UK by CPP
available thru summit, jegs, ebay etc.
unknown quality on the bushings/balljoints.
if you want OEM quality with premium bushings and balljoints i can build a set to spec for you. here's the last pair i did:
Sorry my bad. I think originals are small ball joints. They were replaced but wouldn't tighten in the hole. They were rack welded but one has broken loose and pulled out.
I haven't seen anybody offering the small balljoint stamped arms new. Tubular, yes. They may be out there somewhere, but I haven't seen them.
Factory stamped arms you'll most likely need to find good used units.
correct, original uppers from 62~72 were small ball joint.
welding joints into the arm is pretty common.
QA1 makes tubular uppers in small joint, as does firm feel. i'm not sure who else.
for stamped steel, "rare parts" makes a small joint arm but i've never seen them and every listing has them as "will be special ordered for you". however given the quality of the "rare parts" brand parts i've seen, i'd pass.
You’ll need to look for good used ones. They should be in abundance. I just sold a set or would have helped you out
So many guys are replacing their small ball joint arms with large ball joint arms that you should be able to find a used pair pretty easily. I'll have a pair available soon, but shipping and would be a killer from Canada, to say nothing of the tariff you pay on auto parts coming from Canada.
Bob, keep in mind, if you FIND original Chrysler a arms, they do not come threaded. The ball joints cut their own threads.
6374SCA-UK by CPP
[/URL]
I didn't realize that there was another maker of stock-style stamped UCA's. Thanks!
btw- some of the comments on Summit's website are pretty funny. Apparently people were buying those expecting to install them with their pre-73 knuckles.
i'm not sure if they're another maker per se, but they have them in their catalog for a whopping $252 each, and this is purely speculation, but i'm *guessing* that they're the same arms everybody else is selling and they're just middlemanning it out.
anyway here's a link, so draw your own conclusions
also, here's their version of the moog offset uppers
a little on the high side, me thinks.
the summit comments are odd, i notice that sometimes there are answers and replies from other, similar products in there. however, if you dig a little deeper you'll notice that the info on fit is just as clear as mud between summit's description (or lack there of), whatever "expert" is answering and joe schmoe chiming in, i can see how easy it is to get lost in the woods there.
Thanks to all of you that provided good sound advice and Information. Y'all provided what I needed. To those who were more concerned with where I was supposed to be posting my questions... well whatever.
We dont care where you post. Its the moderators who make the rules who care. Thats why first post was deleted. If you dont care about moderators deleting your post then do what ever you want
