Upper Control Cam Bolts Turn
howco4
Renton Wa
The upper control arm cam bolts, (passenger side), on my 70 Dart will not stay locked in place. I've replaced the stock bolts with ones from Mancini Racing, hoping to correct the problem. They have more thread length, allowing for a larger nut. Short of welding them in place, I've run out of options. Any help appreciated.
You can take a chisel and chisel stakes in them and on the frame brackets they tighten against to make teeth so they will not slip. I've done it several times. Works good.
Sounds too simple. I will give that a try. Thanks for the good input.
