68383GTS
Ok in the next few months I should be painting a few places on my Formula S.Like the bottom side of the roof,top side of the floor and trunk pan,and the back side of the firewall.And by the end of fall I hope to have the door jambs and engine compartment painted.By the way as of now the color will be black.
My question is my Unlce who will be doing most of the painting wants to use 2 stage urethane aka base clear coat.
My questions are...
1.. Whats the differances between single stage and 2 stage.Cost?,Durablity?,etc.
2.. Single stage you mix and spray and it comes out glossy right?
3 Which single a two stage would hold up better, under the hood and on the bottom side of the car?
4 If I had you repaint a fender or a spot on the quarter panel later on down the road,which one would be less trouble to do.single or 2 stage
5 I think most importantly which one is the most durable.I plan on using good stuff.Hell my primer is $450.00 a gallon.
Here is my thought spray the engine compartment,bottom side of the car,bottom side of the roof,jambs,and the floor and trunk pans in single stage.Why?because you have no clear to deal with and it maybe more durable???
Spray the out side of the body in 2 stage....
Myself I have sprayed enamel and 2 stage urethane so I am not totally lost.
Thanks,Jim
My questions are...
Thanks,Jim
