crabillac
Active Member
- Joined
- Apr 1, 2010
- Messages
- 31
- Reaction score
- 2
I have a set of 64.5 cc closed port heads taken from a 66' 273. They were reworked, and the valves were opened up to 2.02 for some reason or another. I want to use them on a 1975 360 with 9:1 pistons, and a larger then RV cam. Will these heads work with my application, or should I use the original generic heads, and trick them out some way or another? Also what is the difference between the way that a closed port, and open port head functions?
