using primer
trbodrt
so. cal
Is it okay to use a self etching primer to bare metal, then an epoxy primer over that.
Yes, but only after the etching primer has fully cured. Etching primer contains acid which can react with the coatings applied over them if they are put on too soon.
Why not just use a dtm (direct to metal) epoxy and skip the etch?
Rjs,
got any name brands to look for in this category? I'm at the bare metal stage and this is my next step.
Trav
tcpglobal or Eastwood carries several brands of Epoxies if you dont have any autobody supply local for ya.......
I have RM EP789 in the shop right now...(mixes 4-1-1).
