Carter it is indeed. And it has definately seen better days...
I knew the choke was crap as it's all disconnected except for the vacuum hose, which I'll admit, is the port I was trying to use...this doesn't explain why my distributor will kill the engine when I apply suction to the hose though, just the slightest bit=shutoff.
The only way to start the car is with starter fluid, once it's warm/started and run for 3 minutes it starts immediatly no hesitations...
But it never runs perfect. It's pretty smooth through the RPM band, doesn't hesitate of the line ever, just skips and misses every so often, predominantly at idle, maybe at higher RPM it's just not noticable.
I'm the kind of person who gets irritated by an even slightly poor idle.
Anyway as the picture shows, the vacuum advance port has been crudely sealed. The whole carb is a mess, I don't trust it one bit. By the looks of my distributor it's in about as a good a shape.
C130 Chief and others make a very good point, the carb is obviously set up to compensate for it's own shortcomings and that of the distributor. I replaced my plugs the today, ran the car 5 miles and pulled #2 and #5, they were both black. It's set up way rich.
As the trans needs to be pulled and replaced anyway I'm just going to have to save for a new 4bbl and intake like I wanted and a new distributor. This whole thing is a mess I don't think is possible to save/get running right with these parts on there...It's so frustrating, I wanna drive the damn thing already!
Thanks for your help anyways...
Pictures of the hunk o' junk:
The current "hookup" for the vac advance, God only knows how long it's been like that and what kind of moisture has gotten into the pot which could cause all kinds of mayhem with an electronic ignition like mine...
The distributor with cap off:
