Vacuum pressure on the 170
Bock120
Member
Idaho
Going to check vacuum pressure on my '63 valiant. what should the pressure be?
Your wording is a little confusing....
Pressure is the opposite of vacuum...
Vacuum is negative pressure.
Are you referring to intake manifold vacuum? I would say you should expect 17" hg at idle on a used engine give or take....
Maybe he means compression? I just love these guessing games.
don't forget to stop the muffler bearings from spinning while doing this...
You got me, i was talking about vacuum on the manifold side. I have 18" hg, that is with the muffler bearings not spinning, I have around 10" hg on the timing side. The hose looks reasonable, haven't checked it really well, but what else should i check for problems.
If it's not the blinker fluid then I'm stumped! Others more well-versed than I will surely chime in.
Expressing "vacuum" using the term "pressure" is completely legitimate. No different than the many ways of expressing the two in terms of different measurement standards, whether "pounds per square inch," or inches of orange juice.
In fact, in a different life, I used one of these................
Which is a Bacharach brand oil filled manometer. The thing is, while it is marked and calibrated in "inches of water" that is NOT what is IN it. So it actually does not MEASURE "inches of water," because the OIL that is used is not actually responding to the same height. In other words, if you would substitute an "inch ruler" for the calibrated scale, the instrument would read incorrectly
The point?
You COULD build yourself an instrument that reads in "millimeters of sludge." Or in "feet of 3-in-1 oil" It just so happens that water and mercury are two standards that we "use a lot."
The point?
Isn't that a ***** pump vacuum guage? :D
thanks guys appreciate the useful information. I'll remember to be sure to use the correct language when asking for help.
My point is you DID use the correct term. Aircraft engine manifold "vacuum" is expressed in pressure, whether under vacuum, or supercharged under pressure
At least some of these measure "absolute" manifold pressure, meaning, when the engine is stopped, and the manifold is at atmospheric pressure, the guage will read barometric pressure instead of zero like an automotive vacuum gauge does.
Pressure is pressure. It can be "negative" that is lower than absolute atmospheric, or "positive" like in a tire, higher than atmospheric
