Valiant 1968 4 door rear window seal / gasket
1964 Signet
Member
The Netherlands
Rating - 0%
0   0   0
Hello everybody!
I just found a real solid 1968 Plymouth valiant 4door
Unfortunately the windshield and rear window have been removed
I do have the widows but no seals / gaskets
I want to buy those and the front rubber seal is available here and there but the rear seems hard to find
Some companies do list seals for a 69 and up but not for 67 -68
Can anyone tell me what the difference is between like a 68 and a 69 rear window opening and or seal / gasket? (as far as I know body is the same, right?)
Or even better can you send me a link where to buy the correct ones
I am located in the Netherlands in Europe
Thanks for looking!
Best regards
Davy Hesen
Looks like Dante is the place to go for the rear glass weatherstrip for your 4 door Valiant.
From the Chrysler parts catalogs:
Plymouth Valiant 4 door rear glass weatherstrip:
1968 - 2841826
1969 - 2963972
1970 - 2932972
1971 - 3500480
1972 - 3500480
1973 - 3500480
Chrysler superseded 2841826 to 2963972
Then superseded 2963972 to 3500480
So according to Chrysler 68 - 73 are interchangeable
From 1968 till 1973 the Valiant and Dart had a different rear glass weatherstrip but in 74 thru 76 both models used the same weatherstrip #2839646
