Valiant Fender
Valiant200
Active Member
Hello everybody!
i have a major question about 63-65 Valiant Fenders, are the all the same?
my 63 Signet Valiant has a very rusty damaged Fender i have the opportunity to bay a 65 V100 4 Door donor Car
fit the 65 my 63 Valiant?
greetings Tom
Yes. Models changed in 63 and ran to 66 then 67-68 had diff body style also round sidemarkers then 69-1972 then 1973-1976. The rear quarters are where you will have troubles from 4 door to 2 door. The v 100 v 200 etc where just option models on exterior trim inter etc. Hope that helped
The body lines on the 63 and 64 are the same but in 65 they made the sideways V shape narrower. In 66 they removed the body line all together.The front end assembleys are interchangable but as for fenders you need a 63 or a 64.Unless you wanted to change the whole front nose(fenders,hood, grille,etc).
64 and 65 Barracuda have the narrow "V" on the fender too, so you would be looking for a 63 or 64 Valiant fender.
You could swap the front clip from the donor car and only purist would know that the clip had been changed. Fender to door lines and all bolt holes match.
