Valve cover breather set up suggestions
Paul Davidson
Texas
I have a 360 magnum with magnum performance valve covers what breather or pvc system works best
I've used a PCV valve in the valve cover that runs through an air compressor water trap and then into the side of the pluneum on the manifold. Worked flawlessly, and during the winter it would need to be drained weekly to keep the water and small amounts of oil out of the ventilated air. I also used a vented breather on the opposite valve cover.
How well does your cold air setup work been thinking about doing something like this
It was noticeable by the seat-of-the-pants dyno. I'm sure you've felt the air blast on the highway when opening the interior vents. Here's the link to the place I ordered my air cleaner from.
I used a couple 4" duct flanges and dryer hose to finish the job.
