Valve guide cutter
440 Mike
Minnesota
So after mock up I need to shorten the valve guides for more retainer to valve stem seal clearance. I have a cutter and arbor from from Comp Cams and my question is should this be used with lube or dry on the stock cast iron guide bosses?
Dry.
