Before All that I would recommend a leak-test on that cylinder with the valves adjusters backed off. Then after I get a number, I would lightly bop the valve stems with plastic tipped mallet; and see if the leakage number changes. If no change but the number is good, like 4 to 8% max. Then I would check the valve stem heights as already mentioned, to be sure that these two are not suddenly sitting higher than the others. And if they are similar to the others then I would swap the rockers over from another cylinder. And if that makes no difference then it has to be hydrolocked lifters. I know it's the long way around to just popping the lifters out and replacing them, but with this rigmarole you know exactly what is wrong-no guessing.
I too run a very light preload; 1/2 turn. Yeah they have to be adjusted more often, during the break-in; but after that they go many thousands of miles. Years even. And the payback is no lifter pump-up, and an engine that revs until it floats the valves,or starves for oil on the rods and blows up. But there are fixes for those too.
