Valve lash question
Babyblue66
Cool dude
In an apartment, MN
Why is it some solid cams will have say .011 lash and others call for .22 or more?
Is it the shape of the ramp that determines lash?
I have heard of guys adding or subtracting a little lash from the specs called for to more finely tune the engine. Like a few degrees.
I worked for a guy and the Vette I was working on idled rough and you could barely here the tapping of the solid cam. He told me to add a few thou of lash. It ran smoother and you could then hear that nice solid cam sound. It really helped by, basically removing some duration.
I guess this could be done in reverse also, tightening a little, to add a little duration.
Just something I was thinking about.
depends on the ramps that are ground into the cam.
And yes with the loose lash cams you can play a little on the lash, I don't think I'd tighten a tight lash cam though.
