I purchased this head gasket set when I was replacing the springs on my 273 and the valve seals that came with set seem to be too large on the bottom. The diameter is much larger than the old ones but the actual hole that the stem pokes through is nice and tight. Is this supposed to be the case on new seals or did I get a one size fits all type of seal?
Clevite HS3536A: Head Set Chry Dod-Pass&Trk Ply-Pass&Trk 273 318 2B.C. Eng. 66-74 | JEGS
