mattsinger
My son and I are in the early stages of building a 383 for his 72 Charger. We have purchased a set of comp cams 911-16 valve springs to go with the cam....however I have a question on the retainers. Will the stock spring retainers work? With stock springs the retainer is the same diameter as the spring. With these new springs....the retainer is a bit smaller. Should the retainers be the same diameter as the spring??
Matt
Matt
