I am looking at ordering a roller cam and springs. I want to give the manufacturer as much info as I can. So I need to know the following. These numbers should be what the factory put in. I am pretty sure on a couple of them, but would like conformation. Also, how much pressure can stock adjustable rockers take? These are stock 340 "X" heads.
The factory specs needed.
Valve length
Valve diameter
Spring installed height
Spring diameter
Jack
Valve length
Valve diameter
Spring diameter
Jack
