SRT_DSTRHOLC
How can i tell if my drive shaft needs to be balanced or if the pinion angle is causing the vibration i have.... other poss. are front suspension being so old and manual steering box...
Does the vibration happen when you are sitting in park? Does it come and go with vehicle speed and rpm? Does it get worse on heavy acceleration or deceleration? Are there any perceived sounds associated with it? Have you measured your pinion angle and found it off?
