340 with manifolds and Huges 334 cam on 109 makes 388 hp @ 5900 rpm and 380 tq @ 4500 rpm.
Fairly respectable numbers, I just skip thru his video's, I find them too dry, thought others might like it.10.6 to 1 180 psi intake 750 dp 238@50 540 lift 109
headers only added 11 hp 10 lb ft
fully tuned
should be a sticky
Here’s two videos I posted in the last week or 2 on my Duster build.
Yeah, I am. The AX-15 has a spot for a speedometer gear but it wasn't knocked out or have the retainer bolt hole tapped, so i just had a steel plate cut locally to fit in the factory bezel and fit my aftermarket gauges and an old GPS we had layin' around.You using a GPS as a speedo ?
