Vin # question
trudysduster
Corinth, Ky.
Where on a 1966 Valiant did they put the vin # other than the tag inside the front door pillar.
There's a partial VIN also on the radiator support.
No there are not. There's an SO # there. Partial VIN didn't start intil '69 on body stamps...
Ok my bad. I knew there was something up there. The whole serisl number, SO number and VIN thing kornfrooshes me.
68 and older...
Only way to link a VIN to a car body is to have any of the following...
Build sheet
IBM card
Certicard
68 and older...
Build sheet
IBM card
Certicard
I have the build sheet. No IBM or Certicard. I have the plate on the door pillar on driver side with vin # on it and thats all. No core support or anywhere else on the body. I know my 76 Duster has it in 3 places I believe. thanks
If you have the broadcast (build) sheet, that will have both the VIN and SO numbers on it. Both should match what's on the car. I believe a window sales sticker would have the VIN also.
What is the SO #. I have the vin #. I have the build sheet and there is a vin plate on the driver side door pillar but I was wanting to know if Chrysler in 1966 stamped the vin anywhere else on the body itself like in later years.
I don't know when they started stamping the SEQ / SO number on the body but on 67 up it is under the rubber seal on the driver's side trunk seal about 1/2 way from front to back of the trunk opening.
It might be hard to read if there has been a repaint or two.
This is related to B body but you never know
1966 Hemi Charger Help ID
