[SOLD] Vintage Cragar Wheels
Dwayne Fairchild
Active Member
WIS
Rating - 0%
0   0   0
A set of four pre 1970’s Cragar SS wheels.
Two 14”x6” P195/75/14 and two 14”x8” P235/60/14. Bolt pattern 5 by 4”. These wheels are in very good shape considering they are 50yrs old. Tires are 3-4yrs old. Tread is good. Lug nuts included. Looking for $400 OBRO. Located in 54956… possible delivery since I travel through Wisconsin, Iowa & Minnesota….
Is there chrome under the paint? If not, those may be the G/T wheel, they had a painted center.
it looks like some of lug holes are wallerd out. cant tell for sure
Here’s a few more photos.. for being 50yrs old, the bolt holes look pretty good. I don’t know that to factual, but I was told this number on the back of the wheel was a date code of 1964… again… I’m not sure this factual…
The two 195/75/14’s are Firestone and the two 235/60/14’s are BFGoodrich. They are a few years old but plenty of tread life remaining
4" Bolt Circle seems more plausible to me
Yep those are Cragas they're also fit another bolt pattern if you notice in the attachment package baggy The oblong spacers or adapters, crome was shot so someone painted in Black
Sorry… unknown history on the wheels. I decided my 66 Cuda needed a new look. Hopefully someone on FABO can find a use for these vintage Cragars.. a reasonable offer would be consider..
Yes and no. They are Cragars but not Uni-lug. They are pre drilled for the 5 on 4" bolt pattern. That's what the "4BC" stands for. The washers in with the lug nuts are for some other wheels. Check the lug nuts and make sure they are 7/16". My bet is that they aren't.
Washers are the same I use on my Cragar G/Ts. Only offset washers fit. Mine are 4.5" pattern.
You can see the S/S wheels in the background, I'm now convinced the wheels you are selling are the G/T model, compare the spokes.
Yes my bad I didn't take a close enough look I thought they were un-a lugs. I stand corrected.
