I have A 70 swinger that came with a vinyl roof that's no longer there. I see that the repops come with 39 and 43 inch seams. Does anyone know which is the correct one for a swinger?
If the roof has not been painted since the vinyl was removed, you can usually see the seam lines. I can measure my 73 but I dont know if it will be correct for your 70. Either one will fit if thats all your worried about.
Mine was measuring around 37.5 so I assume its the 39". This is on a 73 swinger and its the same as the original was.
I do have a 70 swinger as well but the top is already off and someone epoxy'd the roof so nothing to reference on that one.
