VIPER 6 SPEED
blasterboy360
Member
wv
HI...ON A 360 LA ENGINE...IS THE BELL PATTERN THE SAME AS A VIPER...WANT TO INSTALL A VIPER 6 SPEED...I THINK ALL V8 SHARE, SAME BELL PATTERN..ANYONE DO THIS SWAP..PARTS USED...WOULD BE GREAT..THANKS...
QuickTime makes conversion bellhousings for what you describe. I do not believe the Viper V10 bellhousing pattern is the same as a small block and I know that all V8s do not share the same pattern; e.g., LA small blocks share pattern with other LA small blocks and big blocks share same pattern with other big blocks.
I would recommend accomplishing a search for T56 on here. I know there are a couple threads about it. Member dustbull has a couple really good threads with part numbers and all mods required.
THANKS..WHENT ON T 56....GOOD INFO....
