harvenator
A fish called Wanda
I built a 273 and the guy who did my heads installed new valve guides, new valves, new springs and cut the valve bosses for Viton seals. It only has a few thousand miles and smokes when I let off the gas. I pulled the plugs and it looks like 3 cylinders on the right bank and 1 on the left are using some oil.
I've already eyeballed the seals by pulling the springs with the heads on and they looked ok but think there may be some reason for them to pass oil. How can I replace the seals without taking the heads off. I want to use Viton seals again.
If that's not possible, can I cut the seal away and install the stock style umbrellas?
