Voltage Regulator adjustment
Wayne Miller
1962 Dodge Lancer Wagon
Barrie Ontario Canada
Can this regulator voltage output be adjusted?
It is a VR101
Exactly what seems to be wrong? V too high, too low, ?? what?
Yes but be sure you NEED to
Most voltage problems are not the regulator. They are voltage drop problems, AKA drop in the ignition circuit feeding the VR as well as the gronding
Best thing you could do is scare up a solid state replacement. Most regulators that look like those are actually not mechanical internally.
