Voltage regulator options?
ricomondo
Lake County, IN
I see now that the voltage regulators now are no longer stenciled and have a cheap sticker with the part number and date code. Is there any other options for these? Is anyone rebuilding old vintage ones? Thanks!
You can find NOS OEM and aftermarket.
If you are looking for the oem text that's about your only option. Keep in mind that the VR will be electro mechanical
My assumption is you are looking for a old style square box type rather than the 70 something electronic type with the v shaped connector.
I purchased one on here from a member but I can't find the conversation to give you his name. Perhaps do a search for NOS OEM voltage regulators. I purchased one from him because the one from Oreily's was putting out like 17 volts and fried my AC ECM, then I got one from NAPA and it was putting out like 15.2 volts if I recall. I think all the new ones are from China and they stink.
