Vehicle was running . Ran for 5 to 7 minutes then would die connector to the regulator was bad changed it ran fine started one day then died . Now it doesn’t start at all will crank though?
Let's get some basic info here...Have the old square kinda flat regulator on my 67 barracuda. Has anyone swapped that out with the newer smaller square types thanks
so got under the dash moved some wires from the ignition around vehicle started up . Must have a bad connection somewhere. Going to have to find it,
