[SOLD] w2 heads intake & carb price change
modart440
Rating - 80%
4   1   0
w2 econo heads for sale. 68 cc open chamber2.08 x 1.60 valves. Valve springs good to 650 lift with titanium retainers.These are bolt on and go heads no work needed.No repairs ,damage or helicoils.Econo's have traditional LA shaft mounts .Mopar Performance M-1 intake. Holley 750 DP carb billet base & metering blocks ,4 corner idle (works amazing with great throttle response).Parts are located near Toronto Ont Canada.
Heads 850.00 pr US (rockers are sold)
Intake150.00 US (sold)
Carb 300.00 US (sold)
w2 econo heads for sale. 68 cc 2.08 x 1.60 valves. Valve springs good to 650 lift with titanium retainers.These are bolt on and go heads no work needed.No repairs ,damage or helicoils.Econo's have traditional LA shaft mounts .Mopar Performance M-1 intake. Holley 750 DP carb billet base & metering blocks ,4 corner idle (works amazing with great throttle response).Parts are located near Toronto Ont Canada.
Heads 1200.00 pr US (rockers are sold)
Intake 200.00 US
Carb 400.00
All prices negotiable
I'll take it all, please P/M price with shipping to 53590
Spoke with the owner about it, it all sounds like a good setup. It would require me to change my short block up more then I was expecting so in the end it was not a good fit for me. good luck with the sale mopdart440.
carb is sold
intake is sold (Rumblefish)
price change on heads 850.00 for the pr
Which exhaust pattern do they have? Early W2s had std pattern, later had dual W2/LA patterns both drilled
Rockers are sold. Std bolt pattern. Hemichuck I'll let you know about shipping heads are sold based on a shipping quote. If it falls through I'll let you know.
