W5 Abody Headers ??
Dartster66
Active Member
Florida
Looking for a set of W5 Headers or If anyone knows who is manufacturing them since TTI discontinued making them .
No one/ good luck, consider used or customer headers.
This topic was justhe covered by a lady looking for headers for her husbands W5 engine. Do a search.
Thanks. I’d guess low volume and the Victor replacing it, in a manor of speaking.
I think that head will take the same header if you use an adapter plate that fits that head. IIRC from the guy posting on moparts they either moved the port up or dropped the bolt holes down.
So, you don’t know for sure then?
To the OP, I’ll have to dig up some gaskets between the two heads and see what’s what. I’ll also be honest and say this is gonna take a while to find. I am near sure to have both gaskets to each head. W2 & W5.
I never heard of an adapter plate needed for a W5 head. The older W2 heads used an adapter plate.
Which web site?
He was talking about the TTI web site.....:realcrazy::wtf:
If you're going to use W2 headers on W5 heads you must have a new adapter plate. The exhaust ports on the W5 heads are higher than the W2. depending on what headers/starter you're using watch out for the header coming in contact with the terminals on the starter. I believe I was using Hooker Super Comps and had to insulate between the two. I made my first adapters out of 1/4 aluminum but later had to go to steel because of the flexability of the alum.
