Wanna go for a ride in my Cuda??
wonderful i can almost smell the burning rubber! :thumrigh:
maybe i should get my duster out of the garage tommorow and demolish a set of MT H50-14 just to post it here and make my neighbours happy with the sound of open headers again! :lol:
DJVCUDA wrote:
It is a mild motor, if you ask me
It may be, but there's a whole lot of shakin' going on under that hood. :thumrigh: That thing sounds NICE!
BadAssDodge wrote:
heres some videos of my car
:thumleft: If you don't have your screen-name on the back of that Dart, you should! 'Cause that is definately a BadAssDodge! :headbang:
DJVCUDA said:
For the motor, heres what I have...
78 360 - standard bore
stock valves, MP valve springs to match the cam
stock bottom end + kb flat tops + windage tray
high vol oil pump
double roller timing chain
mp p4452992 - .474 lift 280 adv dur cam
eddy street tunnel ram - jet hot coated with milodon valley tray underneath
2 holley 390 vac sec carbs with lightweight spring kit and balanced secondaries
mp electronic dist + lightweight spring kit
jacobs coil
taylor purple plug wires
champ plugs with .55 gap as per jacobs coil
mp 175k converter
904 + b&m transpack
3.32 sure grip in a 8 1/4 rear
It is a mild motor, if you ask me, I dont have alot in it, just a combo that I have been working on builfing for at least 5 years... piece by piece... here's another vid!
http://www.abodyjoe.com/pictures/Dave/20050308_000705.avi
http://www.abodyjoe.com/pictures/Dave/20050308_000730.avi
:cheers: Tought that thing was a big block... :thumrigh:
It looks a lot like what I had in mind (trans and diff incl.) for my project, except for the 2 carb setup. I guess that weigth wise, your cuda and my dart are not very far (mine is 3200 lbs without driver I think).
Is the stock 360 heads?
Do you have number for that setup?
Flywheel HP and torque?
Wheels HP and torque?
1/4 mile time?
:thumrigh: :thumleft: For your work and setup.
Yes the heads are bone stock... 1.88 intakes and all.
The numbers will be here soon enuff. I just have to get it to the track (atco raceway is 1 mile from me so it should not be long!)
f*** my 904gearbox gave up before i had the chanse to make a nice videoclip.. i will be back with it when i have put my other gearbox in the car and some other small problems solved...
